98 ls1 into 02
Old Mar 25, 2013 | 03:26 PM
southbay's Avatar
Default 98 ls1 into 02
putting engine,harness,computer,from my 98 camaro into a 02 camaro.just relized the 98 has the 3 wire plug and the 02 has 2 plugs.I see that i might have to repin it.do they make a conversion kit,or can i pull the 3wire set up out of the 98.will it still run if i just plug the 2 in for now.just some of the guages wont work?.any help would be apprecated.thanx howie
P:S told my son to check all of this before we started it.another fine mess he got me into.
Old Mar 25, 2013 | 09:04 PM
psiconversion's Avatar
LS1Tech Sponsor
Yes you can use it. The 'C' position is for the gauge cluster.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Mar 26, 2013 | 12:02 PM
the_merv's Avatar
What exactly are you doing..converting a V6 car?
Old Mar 26, 2013 | 12:32 PM
bczee's Avatar
?.. if so.. I would just use the 98 LS1 as a long block with accessories, intake, etc and then find a 99+ wiring harness, sensor, and PCM.. to match your year F-Body. would swap in a lot easier.. You mingth have to extend some part of the harness (Notch Sensor ?). Otherwise, it would be a easy swap.
Also, tuning is a lot better on the 99+ (411) PCM's over the 97-98 ones.
BC
Old Mar 26, 2013 | 12:49 PM
the_merv's Avatar
Exactly..99-02 Engine Harness, and preferable and 02 PCM..
Unless the car he has is stripped of wiring.
