Ls1 5.3 in an 2000 sonoma help!!!!!
Old Apr 2, 2013 | 08:12 PM
Black98s10's Avatar
[QUOTE=sprayed99;17277207]Just a beware of that above mentioned forum.... Lots of attitudes there. I had over a dozen PMs from members calling BS because I finished my full swap in 8 days... Sooooo you were warned LOL.
Bought the correct fittings and line and dry mocked it up and marked everything then took it down to a local hydraulic line place and had them crimp everything. In fact all original factory options worked. Dont mind the fuse box cover missing I had the wideband on it because I was still finishing up the new tune after the last round of work was done.
Here is a few pics for your viewing pleasure
Where did you put your ecu? I noticed it not on the overflow tank
Old Apr 2, 2013 | 10:22 PM
sprayed99's Avatar
[QUOTE=Black98s10;17283630]
No I did not mount it there... Personally it looks like **** mounted there.
It was mounted on the drivers side inner fender next to the washer tank. I used a silverado bracket and some steel sheet I bent up with stainless hardware. My goal was to build a mini silverado so it was fitting.
Old Apr 3, 2013 | 05:56 AM
Black98s10's Avatar
[QUOTE=sprayed99;17284032]
That is a beautiful truck.
By Brett Foote | 2026-06-04 05:00:17
