LS1 PCM fuel pump output question
Old Apr 20, 2013 | 08:26 AM
96lt4c4's Avatar
Default LS1 PCM fuel pump output question
I am helping a friend with a thirdgen Camaro LS1 swap, and I am in the process of going through the wiring harness. My question is does the LS1 PCM supply ground or 12 volts to the fuel pump relay? I looked up a schematic and it looks like it supplies 12 volts to the relay and the other side of the relay coil goes to ground. If so I have it wired up backwards. Kind of weird because the fan relays are opposite.
Old Apr 20, 2013 | 09:05 AM
garys 68's Avatar
Yep, fuel pump ecu output is 12 volt +. On all the rest, fans, etc. ecu provides ground.
Old Apr 20, 2013 | 08:24 PM
96lt4c4's Avatar
Thanks man
Old Apr 20, 2013 | 08:30 PM
aknovaman's Avatar
http://chevythunder.com/BCM_and_fuel_pump.gif
