04+ harness with 01 PCM and engine
Old Apr 22, 2013 | 10:08 AM
bigbumperforlife's Avatar
Default 04+ harness with 01 PCM and engine
Very first issue, of a bazillion more to come I'm sure... I am using a DBC throttle body, a DBC PCM (engine is an 01 silverado, with an 01 silverado PCM), but I somehow got the harness of an 04+. So now my issue is this. One I followed all the guides on lt1swap.com to prep the harness to 04 standards. Mostly its the same as the 01 guidlines except a few things, two primarily being the iac and tps. The IAC I wired in easily to pins Green 77-80. (just where it was suppose to go). Now I need to wire in the TPS, and am a little confused. I have the plug, but thats just the first part. Thoughts? Haven't seen anybody with this particular issue, mostly because they probably managed to figure it out on their own.
