Wiring In A/C Recognition Circuit
Old May 1, 2013 | 10:06 AM
jeeperanthony's Avatar
Default Wiring In A/C Recognition Circuit
I'm wiring up my A/C, and I'm a little confused. The techrods harness has a green and whit wire fir the A/C recognition circuit, but I'm not sure where to connect this in. Does it get 12v when the compressor is on?
Old May 1, 2013 | 12:02 PM
downset71's Avatar
Usually it taps into compressor wire. When it senses a 12v turn on, it makes ECM bump up idle rpm a little
Old May 9, 2013 | 10:44 AM
Okay. SO running 12v directly to the computer in the correct pin will do it? I have an extra wire from the pressure switch I can run to it.
Old May 11, 2013 | 07:53 PM
86MonteSSLS-1's Avatar
I'm pretty sure the PCM uses a 5vdc reference signal for a/c on
Old May 14, 2013 | 07:22 PM
downset71's Avatar
5v? My speartech GM harness had a green wire which i was told to connect to compresser 12v turnon
Old May 15, 2013 | 06:29 AM
TomM's Avatar
Downset is correct. I have used two of their harnesses. Connect it to the wire that brings the compressor on. I connected mine right at the compressor. It does bump idle slightly, and also brings on both fans to move more air across the condensor...
T,
