NSS Wire ??'s
Due to the wiring on the Rover, I am having to use a relay on the NSS wire to turn 12v into a ground output on the relay for the NSS wire to be grounded.
I have battery voltage on that wire when it's not hooked up, that right? Seems odd to me...
Also the rig will crank, and give fuel pressure when this wire is not hooked to anything! I thought it was there to complete the circuit for the starter?
The trigger for the starter is the old starter solenoid wire (ignition switch goes to partial ground when in position III), but the LSx computer is wired to the starter itself.
In my (small) mind, it shouldn't crank and give fuel pressure if the NSS wire is not grounded, and the battery voltage is confusing me.
Over thinking it or what?
Many thanks as always.
Martin
Thus, there is no full ground, or power, when the shifter is in Park or Neutral. No full ground or power = no way to wire in a relay. I could have went with an electronic relay, but didnt have one on hand. So after talking to Bill at BP today, we decided to just leave it unhooked until I need to reset the PCM.
No easy way to put a switch on the shifter itself neither, as there is a shift interlock taking most available room around the shifter.
It's covered now, thanks for the thought though!
Just an oddball swap, the Range Rover, that had 7 ECM's before the LSx one went in there!
Martin
