LS Swap Power Steering Pump Issue...
Old May 20, 2013 | 01:14 PM
PWagon's Avatar
Default LS Swap Power Steering Pump Issue...
This is an engine swap from a 2003 Chevy Express to a 1986 K5 Blazer body. I have an issue where my power steering pump is designed to run a hose to something remote (not sure what - see first picture below). I just need the "old style" cap with built in dip stick to check fluid level (see second picture below). Have any of you guys run into this scenario before, and if so what did you do to fix it? The hos in the picture doesn't go anywhere... it's just cut off at the end.
Attached Thumbnails LS Swap Power Steering Pump Issue...-powersteering.jpg   LS Swap Power Steering Pump Issue...-powersteering2.jpg
Old May 20, 2013 | 01:18 PM
bczee's Avatar
If the pump has three ports, it is a Hydro Boost (Brakes) one. You can just cap off the upper port, which is a return line to the Reservior from the Hydro unit.
Old May 20, 2013 | 02:05 PM
tfi racing's Avatar
You can either get the remote reservoir from the van the engine came out of,or get the bracket/pump assy from a pick up(that way you don't have to screw around pulling pulleys off of the pump).If you find one off of a hydroboost equipped truck just cap off the extra return port as bczee said.
