Park/Neutral Switch Ground for PCM - HELP PLEASE...
Old May 20, 2013 | 01:45 PM
PWagon's Avatar
Default Park/Neutral Switch Ground for PCM - HELP PLEASE...
I'm so close to firing up my LS swap, but I need some help. I need a ground wire to my PCM (blue #34) that grounds only when in Park and Neutral (otherwise OPEN). My truck is a 1986 K5 Blazer and has the stock park/neutral safety switch, but that thing is Greek to me. I don't even know if it's possible to get a Ground connection only when in Park/Neutral. Any ideas? Pictures would be appreciated.
Old May 20, 2013 | 03:54 PM
loweredd's Avatar
It should be a piece of cake on the stock switch. Use a test light, and you should be able to find it easily.
Old May 21, 2013 | 09:21 AM
PWagon's Avatar
I guess I am answering my own question. If anyone of you guys are looking for the exact location of a GROUND ONLY when in PARK and NEUTRAL, then here it is. Use the Orn/Blk terminal on your park/neutral safety switch. Allegedly it only provides a ground (-) signal when in park and neutral.
Attached Thumbnails Park/Neutral Switch Ground for PCM - HELP PLEASE...-parkneutralonlyground.jpg
Old May 21, 2013 | 03:09 PM
ijimmy's Avatar
use your original crank request wire directly to the starter
