dvdswan build
still not sure where I'm going to run it. I've thought of building a cover plate for the lower part of the bumper and placing the cooler behind it. if the rad doesn't work with the fans on it then it may go there and the rad in the bed.
so I think I found some fans. I think I can fit 2-10s in the front lower portion of the condenser, and i'm hoping to fit 2-7s on the upper engine side of the radiator. the 10" is 1250 cfm x2 2500 and the 7 is 1100 cfm x2 2200. is that good? I think is decent after looking at summit and 2-12s is 2600 cfm. also I'm going to try and run them in a X pattern lower left with upper right, 1 set for high temp and 1 set for AC.
10" will pull 4 amps and the 7" will pull 3 amps.
and the best part is they're not $200ea. only $30ea.
so after some searching I found some other fans that had better performance and little bit more money. but the 10" has 2350 CFMs and the 7" has 2200 CFMs.
I received the cooling fans today and I think these will work perfect. but I need to build a enclosure between the radiator and condenser so the fans will blow through the radiator. they will be set up as pusher fans.
the lower hose will fit fine to the waterpump but like the top hose connection I will have to put a 90* connection for them. Called Speedway Motors earlier in the week and they have tight bending aluminum tubing.
did some fitting for the oil pan as well.
