Wiring and ecu question
Old May 22, 2013 | 12:32 PM
b20forlife's Avatar
Default Wiring and ecu question
ok so im looking to install an ls2 with t56 in my notchback. Now ill be putting an dbc throttle body on. I will be using a 24x motor. My question is if i get a stanalone harness for an ls2 with dbc will i be able to use an ls1 ecu? Reason for wanting to use an ls1 ecu is because i plan on keeping ac. I read that the ls1 ecu can control ac compressor shut off at full throttle unlike the normal ls2 ecu. thanks in advance.
Old May 22, 2013 | 02:35 PM
87lsttop's Avatar
as long as it has the driver for the dbc in it or it came off a dbc car.
