Bulkhead or inline connector for engine wiring harness
Thanks
Thanks
Thanks
http://www.iimuchfabrication.com/electrical.html
Andrew
One thing to note is either route will require a special crimp tool to make the connections properly.
http://www.ebay.com/itm/22-Cavity-Weatherpack-Bulkhead-Connector-Kit-12-to-20-AWG-w-Locks-/230837733667?pt=Race_Car_Parts&hash=item35bf004923&vxp=mtr
very nice, easy to put together.
I have the crimp tools for the weatherpack and metripack (at least the 150, not sure if that is the same one for the 280/480 referenced on the 30 pin), so those are catching my attention. The Molex sure are nice and I have seen those used in vehicle applications. The Molex XRC crimp tool looks like it is $300 - yikes!
The pass through grommet is interesting (and very cost effective) as well. I never really thought about that. The packaging size on that ends up being significantly smaller. I need to do some sizing up on the space I have available.
I assume you guys end up using 3 (or 4) of the 20-31 pin connectors, right?
I'm still doing my research, but your point is well taken...
More details for anyone following this or searching it later:
I found it at Summit for sub $30 like you said: Link to split grommet at Summit
- Available with holes from 1/4" to 1" in 1/8" increments.
- I also found that the overall outer diameter is 3".
Seals-It Website
At the same time I think everyone has had issues with wires chaffing on sheet metal edges and causing intermittent shorts. That kind of bug will flat drive you crazy. Obviously keeping the grommets in good shape and you have a single point of failure. But still, if you build the connector right it and do a lot or maintenance being able to disconnect the wires rather than tugging them out of the way might be the better option.
I'm talking (the integrity of) factory connections vs. home-built. You never know what you're gonna get when home builders do connectors. For instance, I always solder all of my electrical connections and thought that was the best way until reading posts by PSI harnesses. Now I may re-think my methodology...
Those of you that are using the Molex connectors (like the Molex XRC), what are you using for crimp tools? I can't find anything less than $300. But, I have found multiple places, including the link above, that says you can use standard crimp tools. To me a standard crimp tool is not $300, so they must know something I don't know...
Just like those but in the 35 pin version.
Here is a quick video I did of the wiring project so far.
