1977 camaro RS 5.3 build
Engine: 5.3 .030 over speed pro pistons/scat rods, factory crank polished
Stock heads cut .020, trick flow springs retainers, Thunder racing 224-112 cam,
GM performance lifters, billet double roller timing chain, ls2 intake w/edelbrock 90mm cable throttle body.
Pan: 99-02 F-body (Fits perfect)
Headers: Hooker for 67 camaro (bought before proper ones came out)
Motor Mounts: Home made
Not sure what im doing about injectors yet, was thinking of just using stock 5.3 ones if they would be up to the task?
drivers side ok, not great its pretty close to the rear lower a-arm mount
Passenger side no good had to "massage" to clear rear lower a-arm mount
