What is this wiring harness connector for?!?!
(still havent found it) i came across these two connectors which are up by the bank 2 injectors. Now i dont know if this is where it usaully lands on a stock camaro harness because i have deloomed and untaped my harness. As you can see in the pictures ive got them hooked together because that is how im assuming they should go but i have no idea what they are for.As you can see it is 3 wires that run up to like the end of the fuel rail to the one side of the connector then the other end runs up to that and back into the harness.
I usually remove the extension or cut it out and spice it together.
