ls/lq4 computer to LT1 style 4l60E HELP!
Old Jun 2, 2013 | 09:56 PM
cammednasty's Avatar
Question ls/lq4 computer to LT1 style 4l60E HELP!
I've been doing my research on an lq4 swap into my 94 4l60E lt1 car. I have just a few questions that i couldn't find anywhere here.
How would i go about making the LS computer work with the 94 4l60? Something with one of the shift solenoids not working with the LS computer. Can't seem to find too much info on this.
Also, would the trans move at all switching to ls, I'm not too clear on if the trans needs to be mounted further back mated to an ls motor. Seen people filing their cross members so I'm confused.
Any help would be much appreciated!
Old Jun 2, 2013 | 10:47 PM
the_merv's Avatar
Veteran: Air Force
1994 is not PWM, so you have to account for that. 1996-up 4L60E will work with LS PCM. not sure on the wiring difference but the Valve Body is different in 1994 aswell.
Old Jun 3, 2013 | 09:06 AM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
The harness inside the transmission and two of the solenoids need to be changed. Pretty simple task. Ill PM you the part numbers a little later today.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
