Vortec Hood Clearance
Old Jun 17, 2013 | 07:50 PM
skydude's Avatar
Default Vortec Hood Clearance
Anyone have hood clearance problems when doing a 5.3 or 6.0 vortec with the truck accessories? I have an SS raised hood and working on positioning a 5.3 in my 72' Chevelle. Front clip is off so hard to know how high and how far forward I can go.
Old Jun 17, 2013 | 10:39 PM
PowerAdder's Avatar
I fit my 5.3 in my 71 nova under the stock hood, oilpan 1 mm from cross member. Could not fit the Vortec cover or canister purge valve. Had to flaten out the alternator bolt boss so it would not touch the hood. With you having a cowl I would bet you could position the engine a half inch above the cross member and everything may fit just fine. Alternator may still hit the hood if its out further than the cowl.
