93 Sonoma with 5.3 a/c question
Old Jun 18, 2013 | 07:54 AM
jmyers's Avatar
Default 93 Sonoma with 5.3 a/c question
I have a 5.3 in my Sonoma but I am using all the original a/c equipment from the old v-6. My question is, I had a wire that went to the old ecm and now have no old ecm, not sure if the wire was an input or an output. Can I make this a/c system function without any support from the electronics? It could have been an input to raise the idle of the old throttle body when the compressor came on. One schematic shows a pin b8 off of the ecm that is labled "evaporator pressure control switch". Still not sure if it feeds the switch or if it recieves an input. If anyone has messed with something of this nature I would really appreciate some input. Thanks.
Old Jun 18, 2013 | 09:35 AM
Rick Speed's Avatar
install a pressure switch in one of the lines and run the wiring to the new pcm.
Old Jun 18, 2013 | 09:56 AM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
If you are going to use the existing pressure switch that was on the 93 you can wire it like this. There is only one wire that goes back to the pcm. It is simply for the A/C status signal so the pcm can bump the idle and kick on the fans.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old Jun 18, 2013 | 11:00 AM
jmyers's Avatar
That pretty much simplifies it. Thanks BP
