Tesa harness tape
Old Jun 28, 2013 | 08:50 PM
BOXCHEV's Avatar
Default Tesa harness tape
Anyone using cloth tesa harness tape, purchased from efi connection?
I wrapped this tape around my harness every few inches or so to keep it laid out how I wanted it to sit on the motor. Came back to it a few days later and it's all unraveling. There a technique to using this?
Old Jun 29, 2013 | 12:55 AM
85GPLEf41's Avatar
did you wrap it too tight? I modified my harness using 3m electrical tape and found if wrapped to tight it will either bunch up or unwrap....
Old Jun 29, 2013 | 03:42 PM
BOXCHEV's Avatar
I have been rolling the tape onto the harness directly off the roll, making 2-3 passes around the wire. Then I snip it off and press the end of the cut tape down real good. Few days later its looking like this.
Old Jun 29, 2013 | 04:02 PM
zipster's Avatar
I used cloth hockey tape
Old Jun 29, 2013 | 08:04 PM
-TheBandit-'s Avatar
I'm having the same problem with the stuff I bought from PSI. Maybe there's a trick to getting the ends to stay down.
Old Jun 29, 2013 | 11:11 PM
01cherryreds10's Avatar
I was having the same issue except I was covering the wire with some black braided loom and then taping the ends with the cloth tape. I wonder maybe if you heat it up with a heat gun and get the glue sticky it will seal up better
Old Jun 29, 2013 | 11:36 PM
Figured it out tonight. Waving a flame over/near it just like what I'd do for heat shrink does the trick. It gets just a little gooey and you can push it down with your fingers if needed for it to adhere at the end.
BOXCHEV's Avatar
I plan on using it on the ends of braided wire loom too, I bought 3 rolls of this stuff. If all its going to do is unravle I'm gonna be pissed.
 Michael S. Palmer
Old Jun 29, 2013 | 11:38 PM
There is no glue with the non adhesive tape. It is just friction, but heating it up does make it sticky.
Old Jun 29, 2013 | 11:39 PM
I think it would work okay after heating, but I'm using shrink tube on the ends of my braided loom and it looks really nice.
Old Jun 30, 2013 | 05:44 AM
SSellers's Avatar
Regular harness tape is just for protection of the wires from chafing and it is essentially non-stick. You use something else to secure the loose end....they should almost call it a cover not tape. On old factory cars they tied the end. It is not supposed to be sticky in case you have to remove it for troubleshooting or replacement.
Old Jun 30, 2013 | 07:50 AM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I have adhesive engine harness tape. You will find a mixture of both adhesive and non adhesive tape on newer harnesses. I use a mixture of both on my harnesses.
The non adhesive works better in areas where you want greater flexibility.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old Jul 2, 2013 | 01:05 PM
BOXCHEV's Avatar
I heated up the ends a little with my heat gun, then pressed it down real good and its still holding.
