Map sensor issue?
Old Jun 30, 2013 | 06:47 PM
slownova73's Avatar
Default Map sensor issue?
SO i bought a PSI conversions harness from a member here, and i bought a 2.5 bar map sensor from a member here.
The harness is fine, the map sensor is one that a member in the classifieds was modifying, turning them into 2.5 bar sensors. well i cant seem to find either members to ask them questions.
anyway, the pigtail on the harness is different from the plug-in on the sensor, ive searched for awhile, with no luck really, and not much info.
is there a conversion harness i can purchase? or can i swap pigtails once i identify which one i need?
Thanks.
This is the harness pigtail connector.
And this is the MAP connection.
Old Jun 30, 2013 | 07:48 PM
-TheBandit-'s Avatar
Bosch vs Delphi connectors. I just went through this on mine. I think your sensor has the Bosch connector.You can get a pigtail and solder it in. BP Automotive made a pigtail for me and it turned out great.
