70 cutlass ls3 swap fueling problem
the car idles fine and drives fine cruising. when i floor it and rpm go up, it dies like its out of fuel. let off the gas and it starts back pulling.
i have swapped tanks to the fuel injected tank for the 70 cutlass and i am running a return style regulator set to 58lbs as recommended from psi instructions. i have -6an line from tank to regulator and -6an from regulator to rail. anybody else had a problem like this.
Also.. connect a scanner and monitor it real time or log the inputs from the sensors.
BC
More on topic, you might consider getting a fuel pressure gauge for in the cabin anyway, with a fuel injected car it's nice info to have when troubleshooting.
Classic Spectra symptoms.
