4.8 1500 with 5.7 e fans
Old Jul 20, 2013 | 07:53 PM
98LS1driver's Avatar
Default 4.8 1500 with 5.7 e fans
Not sure if this is the correct place to post but could I put the f body fans from my ss on my silverado 4.8. .?.
Old Jul 20, 2013 | 08:00 PM
aknovaman's Avatar
Been done many times. Remove stock shroud and mechanical fan. Drop in fans and use stock upper mount holes. Cut a pair of straps to connect the holes to the plastic shroud on top and bottom. Import the f body fan settings into your file. Wire them up using f body wiring diagrams found on google images. Pretty simple.
Old Jul 20, 2013 | 10:11 PM
k thanks a ton!!!
