Fuel Gauge after swap
Old Aug 6, 2013 | 05:00 PM
KingPat59's Avatar
Default Fuel Gauge after swap
did lt1 to ls1 swap on my 97 z28 now my fuel guage doesnt work and car has 98 interior harness with my 97 dash everything else works also im using 97 fuel pump which everything on it works fine can help?
Old Aug 6, 2013 | 11:10 PM
KingPat59's Avatar
Bump ttt
Old Aug 7, 2013 | 03:03 AM
KingPat59's Avatar
Originally Posted by KingPat59
Bump ttt
Ttt bump anybody?
Old Aug 7, 2013 | 05:45 AM
Goldhawg's Avatar
I'm probably the least helpful, as I'm still working out my own fuel gauge issues. But more details. If I understand correctly, you used your original sending unit and wiring at the gas tank, but you just changed out the pump for higher pressure. If so, obviously check the connection in the tank--did the purple wire somehow come loose? If that's good it seems like you need to trace the wire (check continuity) between the gas tank and the wire going into your new interior harness, then check continuity between that connection and your dash gauges. Bottom line, you have to find where signal stops.
Old Aug 11, 2013 | 10:14 PM
KingPat59's Avatar
thanks i appreciate it
