Back up lights
Old Aug 15, 2013 | 05:40 PM
Mustang Hat'r 2's Avatar
Default Back up lights
I have 72 chevelle LS1/T56 doing the wiring. How do I get the back up lights to work? Where is the output on the T-56 telling its in reverse?
Thanks
jay
Old Aug 15, 2013 | 08:19 PM
Rick Speed's Avatar
The reverse switch is on the right side of the case. Run power to the switch a d other side to lights and should be good.
Old Aug 16, 2013 | 08:37 AM
Thank bud I remember you, cop car LOL
Right side is ds or ps? I have on the chevelle a single green wire for the back up lights coming out of the fuse block assuming 12V to this green wire will close the switch and give me 12V to the lights. Is the out put from the trans going to be 12V, I have 3 plugs
VSS, Skit shift and reverse lockout?
Old Aug 16, 2013 | 09:54 AM
bczee's Avatar
For my Chevelle w/T56, this is what I did. The T56 should have 4 plugs/connectors.. VSS, SS, Reverse Lockout and Reverse light switch.
I ran a two wire to the T56 Backup Switch (passenger side of the trans).
One went to the Chevelle's OEM backup wire (green iirc, just unplug it from the column switch) Connecting it to the T56 backup switch (passenger side of the trans) plug. either terminal.
Then the Second wire ran from a fused 12 IGN hot wire to the other terminal of the plug.
Then when the trans goes into Reverse.. the T56 Reverse switch would switch on power and the Reverse light would then come one.. nothing to hard about this.
BC
Old Aug 16, 2013 | 10:59 AM
Ok Ill have to look it over then I have a stand alone harness and some things are different ex no oil pressure plug the reverse light maybe the same any one know what the connect style is in case I don't have one and need to order it?
Old Aug 16, 2013 | 11:08 AM
bczee's Avatar
You should be able to pick one up at the local parts store.. have them check there catalogs. If not, there are the usual online stores
IIRC.. this is the correct one that you can order from this place.
http://www.eficonnection.com/eficonn...spx?ItemId=571
Also.. unless your running the BCM and Gauge panel from the donner.. you don't need to use the LSx oil sensor. Use Aftermarket gauge and sender in that location with an adapter or the correct sized sender. you can also use it in the bypass plate in the side of the engine.
BC
Old Aug 16, 2013 | 02:23 PM
mechanical, water temp and oil for the car, gas is easy 90 ohm gauge, VSS works with electric speedo. Car should be running in a week and driving another week after that want to make it as legal as I can
[IMG][/IMG]
[IMG][/IMG]
