Steering Pressure line HELP
Old Aug 24, 2013 | 02:45 PM
sinistral leo's Avatar
Default Steering Pressure line HELP
HI, I put a LQ4 into a 87 Monte SS. I have the Holley Accessory Drive Kit and I'm using the 09 Corvette pump (26120639)
The pressure outlet on the pump is REALLY close to the pulley. I was wondering what you guys came up with for a line from the pump to the box in the past, or ideas that will work...
Thanks!!
Old Aug 24, 2013 | 03:23 PM
Does anyone know if this will work?
http://www.detroitspeed.com/Steering...e-fitting.html
Old Aug 26, 2013 | 10:13 AM
Has anyone tried that banjo fitting? It looks like it would fit with more clearance, but I don't know if it reduces flow or even seals correctly... Thx
Old Aug 26, 2013 | 05:14 PM
KY Nova's Avatar
Look at the topics on page 1 and 2, we have been discussing this in 2 different topics.
Old Aug 27, 2013 | 09:11 AM
1981TA's Avatar
I used a 2001 corvette pressure line on my swap. It fit perfectly.
Old Aug 27, 2013 | 11:10 AM
SWAGON's Avatar
I got the fitting for my CTSV pump from turnone
http://www.turnone-steering.com/
Old Aug 27, 2013 | 01:03 PM
1964SS's Avatar
The pump is just gravity fed from the reservoir. I would not recommend using a banjo type fitting there because it will restrict the fluid too much and starve the pump.
As stated above the stock type corvette hose should work for you.
[Edit]
Sorry I just realized you are talking about the pressure side.
Old Aug 27, 2013 | 10:14 PM
Nobody answered me about the "Banjo fitting" on the other "Corvette post".
Thank you! I'll give that a try!
