Rear differential/Drivetrain
Old Sep 3, 2013 | 11:36 PM
85Sleeper's Avatar
Post Rear differential/Drivetrain
I need some help/info. Will i need to change my rear differential or the drivetrain i have on my truck when i switch to an LS engine? I have a 91 engine in my 85 c10 with a 91 rear differential & drivetrain. Im trying to see if it'll be the same thing when I switch to the ls
Any help/info is appreciated
Old Sep 3, 2013 | 11:45 PM
bczee's Avatar
Shouldn't need to change anything on the Rear.. As long as your drive shaft can connect to it.. and the pinion angle is correct.. your good !
BC
Old Oct 5, 2013 | 11:11 AM
85Sleeper's Avatar
Originally Posted by bczee
Should need to change anything on the Rear.. As long as your drive shaft can connect to it.. and the pinion angle is correct.. your good !
BC
Alright man thanks for the help thats all I wanted to know
