what oil pan for ls 3
https://ls1tech.com/forums/conversio...-oil-pans.html
Many are using different pans and are not using the Transmission Bell Housing to oil pan bolts. But if they do line up.. the better it would be. My Nova w/Holley pan doesn't line up for one bolt.
You should change and use the correct pickup tube, windage tray, dip stick and tube for what every pan you use.
BC
BC
As you noted. the Bottom Bell housing bolt may or may not align.
But would defer to someone with LS3 knowledge..
