which headers?
Old Sep 6, 2013 | 09:46 AM
joshua022's Avatar
Default which headers?
Im looking to buy some Longtubes that will fit my 68 c10 swap with a 5.3.
I know Doug thorley makes some but they are out of my budget.
I have heard maybe the fbody or TBSS headers will fit with minimal issues.
Any ideas? Anyone selling a set?
Old Sep 6, 2013 | 10:05 AM
ijimmy's Avatar
WHAT MOTOR MOUNTS are you useing , cpp has some newer models that will work , if you have cpps older tubular type mounts you are in for a ride , can you weld/fab ? Check this thread
http://67-72chevytrucks.com/vboard/s...d.php?t=586349
I go by the nane 67 chevelle on there
Old Sep 6, 2013 | 10:24 AM
joshua022's Avatar
mine are transdapt's mounts
Old Sep 6, 2013 | 01:26 PM
ijimmy's Avatar
I believe pasesetters will fit your application , they are inexpensive , and occupy the same space as truck manifolds , I believe the set i got were for a 2001 silverado with a 5.3 that is what is in my truck , i just had to modify the front tubes on both sides because of cpps mount design , transdapt does not stick up like cpps do so I think they will be a direct fit , be aware you will need to cut the top of the frame on the pasenger side an inch or 2 , and a slight notch on the drivers side , as you would with stock truck manifolds
Old Sep 6, 2013 | 01:37 PM
joshua022's Avatar
I am running the stock truck manifolds now, so the frame is already cut up.
Which pacesetters? truck/TBSS/fbody?
Old Sep 7, 2013 | 01:03 AM
ijimmy's Avatar
