LS1 into a 1978 Z28
Old Sep 8, 2013 | 07:54 PM
Cstan14's Avatar
Default LS1 into a 1978 Z28
i have an ls1 out of my 99 camaro. i have 1978 camaro z28 i would like to put it in. i know im going to need the harness and computer and all that good stuff, but i want to know if the motor mounts will bolt up, if the oil pan will clear the crossmember, if the tranny will bolt up (its a 4spd currently) i just want to know that sort of stuff so i can plan the build! give me some insight please! thanks!
Old Sep 8, 2013 | 08:50 PM
bentshank's Avatar
You will need motor mounts, headers, cross member if using the 4l60. I used a ctsv oil pan on my swap some guys use the f- body pan. I had no clearance issues. I have not done a swap where I used a manual trans so I'm not sure on your cross member if your using the 4 speed. There are several good second gen swaps on here that give you all the info.
Old Sep 8, 2013 | 09:21 PM
nobreaks254's Avatar
I have a set of adaptor plates for sale as well as a new set of Dynatech swap headers for a second gen camaro. Pm me if your interested or need any help.
