hooked up power steering ???
Old Sep 14, 2013 | 04:58 PM
jaywill's Avatar
Default hooked up power steering ???
IN MY MALIBU..Still hard to turn but not as hard as it was without it ???...WTH !
Old Sep 14, 2013 | 05:58 PM
jaywill's Avatar
No 1 ???
Old Sep 15, 2013 | 06:49 AM
Old Geezer's Avatar
Lines crossed?
Did you bleed the system?
Old Sep 15, 2013 | 09:54 AM
jaywill's Avatar
Originally Posted by Old Geezer
Lines crossed?
how do u bleed it ? i loosen the return side nut an let fluid run out then retightin it up...
Old Sep 15, 2013 | 01:14 PM
gofastwclass's Avatar
The air that concerns you will actually be on the pressure side. Depending on your situation, it could be in the pump itself, the pressure line or the gearbox. I usually have the wheels up with the engine running at idle and turn from left to right slowly several times. ...by several I mean 30 to 60 or possibly more. Do 15 or 20 reps and check the fluid level and look for foam, top off as necessary and repeat. No foam means no air in the system. If it's growling or whining you have air in the pump, If it's hard to turn and there is no noise the air is in the gearbox, pressure line or you have a bad pump (unlikely, but happened to me with a replacement). First you need to try to bleed more and probably top off.
Old Sep 15, 2013 | 03:45 PM
jaywill's Avatar
Happy wheels up in the air
Old Sep 15, 2013 | 03:52 PM
jaywill's Avatar
the wheels r off the ground..could it be i dont have my belt going around my p.s. pulley ? but i have a shorter belt that bypass the pulley but it touch enough to turn it ???
Old Sep 15, 2013 | 08:16 PM
S10xGN's Avatar
Seriously? You don't have the belt on the pulley but it's touching? Did you ever think this "random touching" might be driving the pump backwards? Not to be ugly, but perhaps you should get a friend who knows about cars to take a look...
Old Sep 16, 2013 | 03:42 AM
jaywill's Avatar
damn !!! U r soooo right!! Thanks 4 waking me up !!!!!
Old Sep 16, 2013 | 07:11 PM
jaywill's Avatar
Put new belt on power steering works flawlessly !!!
Old Sep 16, 2013 | 09:01 PM
S10xGN's Avatar
Excellent!
