fuel pump info
Old May 3, 2004 | 08:24 PM
68birdls1's Avatar
Default fuel pump info
i have a 68 firebird that i am putting a ls1 into, the motor will be here on friday, but i want to do some more work on the car now. i am starting to work on the fuel system right now and i was wandering what kind of fuel pump yall are running. i was thinking about an inline fuel pump but i dont know what brand or size. i heard that walbro was nice, not loud or anything and they worked good. any help is greatly appreciated. thank you
daniel
Old May 3, 2004 | 08:58 PM
Scooter70's Avatar
I have a Walbro 255lph inline pump. I haven't heard it run yet so I can't vouch for its sound but it looks pretty nice. Russell hard tube adaptor on the stock tank and braided hose to the pump. It should work well.... (at least in theory).
Old May 4, 2004 | 09:32 AM
68birdls1's Avatar
yea i was told by someone else that that is a good pump! which fuel regulator are you using? and if you dont mind me asking, what size fittings are on the end of your pump? thanks for the help.
daniel
Old May 4, 2004 | 11:20 AM
Scooter70's Avatar
'99+ Corvette filter/regulator. I used the hard tube adapters on the input side of the filter and found a piece of tubing at NAPA that went into the other end, then another hard tube adapter.
The adapter on the pump itself is a 10mmx1 to -6AN. They're hard to find though. I found them at www.lightningmotorsports.com. It's a ricer site, but they had what I needed. The rubber thing around the pump and the clamp-thing came from there too.
Old May 4, 2004 | 11:23 AM
70 LS1's Avatar
Conversion master
I too have the Walbro 340 255lph pump and have had no problems in nearly 2 years. Scooter went all out with the AN fittings, but I cheaped out and went with high pressure rubber line. My regulator is an over the counter 99 vette regulator/ filter with the return dumping back into the tank at the stock return port on top.
Old May 4, 2004 | 02:45 PM
68birdls1's Avatar
yea thats what i planned on using, but i just checkin to see what the experts were using. and 70 LS1, is that pump loud at all? i think for now i will go with the high pressure rubber hose, but i am also gonna be using a fuel cell instead of a gas tank so i think i might just have to save up and get the steel braided hose. any other tips yall wouldnt mind giving me on the fuel system? i really appreciate all the help that yall are givin me.
daniel
Old May 4, 2004 | 03:04 PM
70 LS1's Avatar
Conversion master
The pump is not very loud. I always let the pump run for a second or so before I start the car and you can hear it, but once the car starts, you can't hear it at all. I do have a pretty loud exhaust system and it is a convertible if that matters.
Old May 4, 2004 | 10:19 PM
68birdls1's Avatar
thanks alot, i guess its just time to save alil bit of money now lol. thanks for all the help guys, yall are makin it a lot easier
daniel
