New to ls1 tech. Swapping E30 BMW to 5.3
Old Sep 26, 2013 | 07:01 AM
Boostwhore24's Avatar
Question New to ls1 tech. Swapping E30 BMW to 5.3
Hey guys, I'm new to ls1 tech.. I do have a couple of questions. Like it states above, I'm a couple days away from tearing apart my 84 two door e30 BMW to put a 5.3 in.. I'm really wanting to put a cam in it. Also have to use ls1 intake to clear hood... But my questions are what cam to run? The cam I really want to run is a MS3 with .650 springs. That's really what I'm wanting if I can even run that cam in a 5.3?? My buddy was trying to talk me into running a Vindicator cam. Which I know is way to big for what I want... The motor will be stock other than cam and intake... So guys I need some opinions on cams, and rather or not to run the MS3 the cam I really want. Thanks guys!
Old Sep 26, 2013 | 09:49 AM
superdave84's Avatar
I don't have any input on the cams, however if you're going to go to the trouble of a cam swap, you might want to consider an intake upgrade from the LS1. It works and all, but it's the poorest performing intake of the bunch. I think it's even a step down from the big ugly truck intake in torque.
I'm not the most educated on intakes, as I am just using a stock intake that came on my LS2, but I think the LS6 intake performs much better. You could probably also use the LS6 cam in your 5.3
Old Sep 26, 2013 | 12:15 PM
e30polak's Avatar
What are you using the e30 for? That 5.3 is going to be a boat anchor up front! Make sure to compensate with stiffer spring rate, better shocks, and MUCH better brakes!
Old Sep 26, 2013 | 12:41 PM
brewster240's Avatar
the thing comes with an iron block inline 6, whatchu talkin bout?
weight will be farther back in general, and engine has a lower center of gravity.
win win.
Old Sep 26, 2013 | 12:45 PM
The car is just a junk yard play toy, slide around a couple of times, not a race car nor a drift car. But yes was going to up grade a lot of stuff thanks for the input
Old Sep 26, 2013 | 12:46 PM
I understand man, yeah I've got a couple buddies that are ls guys. But if I can find a good deal on a ls6 intake I will go with it. Buy I need some style ls intake to be able to close the hood
