5.3l swap dies at intersections after engine is warm
It runs great except for this issue. I have put a guage on the fuel rail to check pressure next time this happens. Anything else I might need to look at??
Can anyone recommend a tuner in the Russellville AR area?
I have verified fuel pressure is constant, MAF readout is normal, throttle position readout looks normal, O2 trims look normal.
I do have one unconnected wire that I have labeled as VSS but I thought it was just a spare VSS signal.
Do you have a VSS plugged into your transmission? If not, I bet that's your problem. If your harness doesn't have the proper plug....just a wire, you're going to need to purchase the plug and solder it in. I would be shocked if the plug wasn't provided for you....already installed on the VSS wire. That's pretty basic stuff for a harness manufacturer given the importance of the VSS to the overall function of the engine.
timing, AF ratio, transmission shift points, and to initiate diagnostic routines. So there should be a connection from your ECM to your transmission...independent of the one to your speedometer which is I believe is connected to the output signal. Again...just checking. It isn't clear that you have this Transmission Input Speed Sensor connected. This maybe why you are stalling at a stop. Because your ECM has no idea what timing or air fuel mixture to give you because there is no input to it concerning your wheel speed.
Does it stall at EVERY stop once warm? Or will it stay running if you avoid overdrive? Try leaving the shifter out of OD and see if it still does it as a possible way to diagnose the lock-up function...
