Power steering question?
Old Oct 1, 2013 | 07:04 PM
kevleetee's Avatar
Default Power steering question?
I have an Ls swapped 69 camaro and I'm running the stock type2 pump with an oldschool saginaw close ratio steering box. It is really sensitive and the feel is really light at the wheel. What can I do to take away from the sensitivity and get better feel? I've seen flow restrictors for a saginaw pump with a rack and pinion to reduce sensitivity but not vice-versa.
Old Oct 2, 2013 | 06:06 AM
Old Geezer's Avatar
You can get the same type of flow control valve for the type 2..
U can call Borgeson, and ask for help. Fatman also has the valves, along w/ others.
