75 corvette
Old Oct 11, 2013 | 09:31 PM
87jct90's Avatar
Default 75 corvette
I am putting a lq4 into a75 vette. I am just trying to do a budget build, trying to keep it around $1k for performance parts. What should I get? I have the ls1 intake and z06 exhaust manifolds already.
Old Oct 12, 2013 | 12:41 AM
garys 68's Avatar
I've got an LQ9 in my 68 vette. On a budget...just put the motor in, see how you like it before upgrades.
Old Oct 12, 2013 | 08:28 AM
87jct90's Avatar
Nice, did you do any upgrades to your motor, how do you like it?
Old Oct 12, 2013 | 08:59 AM
garys 68's Avatar
Game plan was cam, L92 heads, etc. But the LQ9 with Z06 exhaust puts out about 400hp. That combined with the Richmond 6 speed would overpower the stock tires anyway.
A kind of after the fact build thread
https://ls1tech.com/forums/conversio...eed-build.html
Oh yeah, the LS1 intake will probably run out of flow at around 400hp. So any upgrades would require an expensive LS6 or aftermarket intake.
Old Oct 12, 2013 | 10:19 AM
74modified's Avatar
Like Gary, I wouldn't do much more to the engine for a budget build. I would use the $1000 to match everything in the drive line. You didn't say what trans you were using. I would use an overdrive and match the rear diff to it. Get the most out of the swap by matching everything.
Old Oct 13, 2013 | 08:38 AM
87jct90's Avatar
Thanks for the advice
Old Oct 13, 2013 | 08:52 AM
74modified's Avatar
I like in tank fuel pumps. Probably not required, but I prefer them. Here is my C3 version. Vetteworks sells a kit.
