LQ4 Pinging
Old Oct 14, 2013 | 06:34 PM
69importkilla's Avatar
Default LQ4 Pinging
So I'm getting what I think is pinging in 5th and 6th gear. I've tried running 93 octane with no success. I'm using the MSD 6010 controller and pill #1.
Doesnt make any sense. The car is over half the weight of the truck the engine was pulled out of. Maybe a different heat range plug? Any suggestions would be helpful!!
Old Oct 15, 2013 | 06:26 AM
Old Geezer's Avatar
Try the tune/diagnostic forum??
Old Oct 15, 2013 | 06:54 AM
I posted in here because I figured this is were the most experience would be found with conversions.
The tune/diagnostic forum says PCM on it, so I figured my carbureted application didn't apply there.
I did put a copy in the carbureted LSX forum, maybe someone can help.
Old Oct 15, 2013 | 08:32 AM
oange ss's Avatar
what carb/jetting ?
Old Oct 15, 2013 | 08:35 AM
Holley 650 DP out of the box. Not sure what the jetting is but I can find out...
Old Oct 15, 2013 | 08:42 AM
oange ss's Avatar
have you adjusted the secondaries ?
Old Oct 15, 2013 | 11:27 AM
No just dropped the carb on right out of the box.
How would the secondaries cause this issue? Not trying to be a wise guy, just learning..
Old Oct 15, 2013 | 11:38 AM
oange ss's Avatar
coming in to late or coming in too early.... read the manual that came with the carb
Old Oct 15, 2013 | 12:27 PM
Still curious if anyone has any knowledge how the secondary's can effect this?
Back to orange ss, thanks! I'll look into it tonight.
Last edited by 69importkilla; Oct 15, 2013 at 12:41 PM. Reason: modified comment's
Old Oct 15, 2013 | 04:19 PM
oange ss's Avatar
secondaries aren't the root cause, carb needs tuned or reduce timing
Old Oct 16, 2013 | 12:49 PM
Renegade6's Avatar
This may or may not be related but, I had a pinging problem on my Silverado that drove me nuts. Ended up being the bendix hitting against the flywheel. Only heard it at freeway speeds under a load.
