LS1-Heater
Old Oct 14, 2013 | 08:32 PM
scaryeyes's Avatar
Default LS1-Heater
How does the water pump work on a LS1? Can I just put a valve on the hose to the heater and shut it off? Or does it have to be constant flow through the hoses at all times?
It does matter, cause in the case of water flowing at all times, the heater can not be located in passenger compatment....
Old Oct 14, 2013 | 08:51 PM
conv55's Avatar
I have a vintage air heater on my LS1 in my 1956 Chevy with the shutoff valve on the output heater hose of the engine and works great, no problems.
Old Oct 14, 2013 | 09:01 PM
i r teh noobz's Avatar
I've seen builds with capped heater ports on the water pump, so I'd assume you can run a shutoff.
Old Oct 15, 2013 | 05:42 AM
scaryeyes's Avatar
Ok. Thanks for answers!
