Alternator Question
Old Oct 21, 2013 | 07:49 AM
mrarmyant's Avatar
Default Alternator Question
I went from the high output truck alternator to the smaller Camaro alternator as it was the only one that fits. The truck alternator connector has two wires, the camaro has 4. where do the two go to the 4. I've searched and searched but keep getting results for the swap going the other direction.
Old Oct 23, 2013 | 11:19 AM
mrarmyant's Avatar
Am I the only one trying to do this?
Old Oct 23, 2013 | 12:02 PM
Sean At CBM's Avatar
The one with 5 volts goes in pin C on the connector. The other goes in B. You only need the 5 volt one to make the Alt work the other is just a return to the computer.
Old Oct 24, 2013 | 04:29 PM
1981TA's Avatar
I believe the pin is the same as the corvette. The pic below shows a Camaro wire plugged into a C6 alternator.
