Narrowing C5 Rear Suspension???
Old May 5, 2004 | 03:53 PM
NJSPDER's Avatar
Default Narrowing C5 Rear Suspension???
hey gang,
along wiht my plans for my '83 camaro i am lookin fo rsomething a bit more radical to try to swap.
i am lucky enough to have a candidate here, 1992 Eagle Talon TSI. it was my bro's car until he popped the motor, now it is a driveway ornament. i was thinking a C5 drive train woudl not be a terrible swap since the car already has a rear suspension that is designed to have power put through it.
anyone know how or where to find info on narrowing an independant rear, if not i can always make an adaptor to use the existing one.
thanks
tim
Old May 5, 2004 | 04:10 PM
70 LS1's Avatar
Conversion master
How much do you need to narrow it? Don't forget you will have to shorten the torque tube quite a bit as well.
Old May 5, 2004 | 10:05 PM
NJSPDER's Avatar
i haven't measured anything out yet, but i am estimating from lookin at a neighborhood vette that it will have to come in about 2inches on each side. that sounds like a lot to me, but i woudl like to knwo the rear is going to last if i do this swap as well.
the torque tube i have started looking into already, hopefuly a call to my local driveshaft adn welding shop will be the solution(pete's welding in trenton seems to always answer my crazy drive train questions)
thanks
tim
Old May 21, 2004 | 09:42 AM
whitelightnin''s Avatar
thanks
tim
Tim,
I just saw a complete C-5 drive train on e-bay including front and rear components. Do a search under complete engines--GM. I'm not sure if it's what you're looking for, but thought this might help.
Bryan
By Brett Foote | 2026-06-04 05:00:17
