Fuel Pump Relay Ground OR Sender Ground
Old Oct 23, 2013 | 03:26 PM
Coonass350's Avatar
Default Fuel Pump Relay Ground OR Sender Ground
Hey guys, I am wiring an LS1 into my 95 V6 camaro. Had to cut the C210 off the V6 engine harness since the LS1 engine harness(s) dont have one. Well I know where the PURPLE starter wire goes and how to hook it up but cant find the "Fuel pump relay ground" or sometimes called "sender ground". I have to find it in the LS1 engine harness and run it into the C210 I got from the V6 harness. It is supposed to be a BLACK wire.
Also the GREY wire on the C210 says "feed to fuel pump & fuel pump relay" do I just run the DARK GREEN/WHITE wire from the LS1 harness and match them up? even though they arent the same colors. The DRk GRN/WHT on LS harness says Fuel Pump Relay Feed-Coil.
Thanks in advance. Any help would be GREATLY appreciated!
