1964 Chevy Impala restore
Old Oct 28, 2013 | 09:01 PM
Nkwats's Avatar
Question 1964 Chevy Impala restore
64 Impala
I have a 1964, 2 door impala and would like to install a 2012 Chevy Camaro engine in it. I have a chance to purchase an entire 2012 Camaro that has been totaled due to roll over. I am trying to find out which way would be best and least expensive, way to do this project.
Having talked to different people some say that I should install the engine and other parts, i.e. brakes, transmission, computers and more from the Camaro, and put into my Impala. Long process and lots of things have to be removed from one car to the other.
I know this will be a long project, but I am looking at just how bad *** my Impala will look with that Camaro engine in it. Damn getting excited just thinking about it.
If anyone can shed some light on this process for me, it would be greatly appreciated. Trying to stay within my $10K budget for this work. If you can tell me what parts I will be able to transfer from the 2012 Camaro to the 64 impala, u will be a life saver. Or if you can tell me what sites will tell me what is transferable Thanks in advance.
I am receptive to any help I can get, especially if you know of a person in my area, who can assist me, in my endeavor.
__________________
Shawn
1964 Impala
Old Oct 29, 2013 | 02:47 AM
superdave84's Avatar
You want to take everything you can possibly get off of the Camaro. Engine, transmission, the wiring harness, fuel pump (and tank if possible) gas pedal, dash harness, computer (ECM and TCM if the car has one) shifter, shifter linkage, exhaust manifolds, front accessories and brackets, radiator, fans....everythign that makes the car go.
Some people like to send out the engine harness to be reworked, and some don't. Depending on your choice, you may want to grab the fuse box(es). I chose to run a stock dash harness and fuse boxes from the GTO I got the engine from, and I will be running a lot of the interior electronics off of the stock fuse box and dash harness.
Brakes...I don't know about all that. It might be possible on some cars, but getting the new stuff to just bolt up to the old stuff does not always work. There are spindles and brackets and calipers and control arms, and it all has to line up. Even if you could swap out the control arms and EVERYTHING brake related, you still will probably run into fitment issues at the frame, let alone alignment issues. They make disc brake conversions. I paid $995 for all four wheels on my '65 from Matt's Classic Bowties.
