02 Camaro to LS6?
The LS6 is a Gen III engine like your LS1 and will just drop right in or you can update your engine with the Heads and cam.
Suggest you do a little research...
BC
or just update your block for a lot less than $6500.. just find a LS6 cam (or aftermarket).. some prep'd 243 heads (or aftermarket) and your there it for a whole lot less.
A) I am obsessed with NA power.
B) this is very built LS6 that laid 702/689 on dyno
C) has very very low miles on it.
D) other than going with Fi, theres not a lot left to do to my LS1, its' met its' NA potenetial or very close to it. and the LS1 is going into something else(64.5 Mustang)
Straight drop in; just need to use your accessories, brackets, oil pan, (and maybe harness/PCM but I'm not 100%).
Is that 702/689 Flywheel or RWHP ? If RWHP, that would be like 835hp range at the flywheel.. .that is a serious build if NA !
Anyway, good luck and keep us posted on the swap and results !
BC
BC
Do you have the transmission, clutch/converter, driveshaft, and rear end to support that kind of power? Your stock stuff might explode at idle with that engine.
specs are:434 Cubic Inch LS6- Darton Wet Sleeve
Cartek Stage 5 Heads- 265 CC- 2.25 Intake/1.7 exhaust CNC Ported
W/ Ferrea Hollow Stem Steel Intake/ Sodium filled exhaust/ Brand New Springs
Comp Cams- 236/259 & 623/623 in @ 112 LSA
Wiseco 4.155 inch pistons = 11.5:1 Compression
Eagle Crank 4 inch Stroke/ H beam Rods 6.125 inch
2 Gallon A.R.E. 3 Stage Dry Sump- Stainless Lines to everything
A/N Fittings for Everything
Runs on a fixed speed density tune not MAF
Intake:
Fast 102 intake/ TPIS 90 MM TB
Carbon coupler
Vararam Ram Induction System
So yes it does make that power. NA!
and yes I do have the tranny, clutch driveshaft and rear to support it. This wasn't a spur of the moment buy, and I am not semi-handicapped.
