Mustang th350 trans question
Old Nov 19, 2013 | 07:46 AM
keving502's Avatar
Default Mustang th350 trans question
Two questions, first can I use a stifflers th350 crossmember along with a AJE k member? Will everything line up or do I need to stick with a AJE crossmember?
second, Found a good deal on a th350 transmission buts its a long tail version. Does it matter what length tailshaft since I'm going to have to get a driveshaft made anyway? Will the trans tunnel have plenty of room?
Thanks
Old Nov 19, 2013 | 07:47 AM
keving502's Avatar
Forgot to add this is for a 93 mustang.
Old Nov 19, 2013 | 07:55 AM
streetknight2's Avatar
I used the stock trans cross member with mine, just modified it.
As far as long tail, I couldn't say, I use a short
Old Nov 22, 2013 | 05:20 AM
keving502's Avatar
So I did some more searching on the long tail version of the th 350 What I've found is that the since the length is very close to that of a T5 I can use the aluminum ford racing driveshaft and have a chevy yoke put on it. Havent actually seen any pictures of it though. Anyone have any first hand knowledge?
