driveline angle at 8 degrees??
1.)Your engine/trans angle matches your rear pinion angle within .5 degrees; if you're setting up a leaf spring drag car, you can run a couple extra degrees of down angle on the pinion to compensate for axle-wrap on acceleration.
2.) Your U-joint working angles are measured and calculated to be at least .5 degrees and no more than 3 degrees.
The 8 degrees you are reporting is not a problem for the operation of the engine or transmission themselves, but is more than likely going to put you outside the recommended U-joint operational geometry mentioned above.
As stated above your biggest concern is with the driveshaft & pinion angle relationship.
Any idea where to measure on the car to check a level chassis.
Sounds like your engine is 8 degrees down in back. Your driveline is only 5 degrees down towards the rear. The difference there is 3 degrees, within the 5 degrees max I've always head. If it stays within those specs, you're ok.
Now you need the pinion angle up 8 degrees in the front to match the motor trans.
The other issue you are fighting is the discrete engine height at the front of the engine that comes with using the common frame stand/SB mounts/swap plates installation. In other words, there's no way for you to lower the front of the engine. This is one of the reasons that the new Hooker 1st/gen F-body/ 3rd-gen Nova mounts eliminate the frame stands entirely and retrofit later clamshell style mounts into the car. Using the Hooker engine brackets and 4L60 specific crossmember will allow you to stuff the engine and trans into your car at a 3 to 3.5 degree angle without requiring any cutting or beating of the floor panels.
