another swap ?
Old Nov 27, 2013 | 05:53 AM
66duce's Avatar
Default another swap ?
I bought a ls6 from a 2001 zo6 that was sideswipped on the passenger side.Needless to say it wipped out the computer and tac. The pedel was fine so I got it with motor. Now the problem. I found a tac from a 1998 c5 which I was able to get. The wrecking yard said that a computer from a truck crossed and supplied me with one at no extra cost. Do you guys think this will work?
Old Nov 28, 2013 | 08:10 AM
66duce's Avatar
Guys im in the process of restoring this car and I dont want to find out next year this will not work and can no longer return any of the items. My concern is the brain is not compatible and that the tac and pedel aren't ether. Thanks for any help.
Old Nov 28, 2013 | 09:02 AM
garys 68's Avatar
The ecu will be a 411. It was used on pretty much every V8 in 01-02, including trucks. You'll need someone to retune for the corvette.
The TAC will need to be from a corvette. I'm pretty sure they used the same TAC from 97-04.
Old Nov 28, 2013 | 06:29 PM
66duce's Avatar
Default swap
Sounds like it will work. Thanks from one gary to another.
Old Nov 28, 2013 | 07:44 PM
BigEd_72455's Avatar
look up LT1swap.com and check his online information. If still uncertain, contact him via email. He should get back to you in a reasonable time.
