2010 LS3 6L80 swap help
Old Dec 9, 2013 | 03:28 PM
mrttype's Avatar
Question 2010 LS3 6L80 swap help
I'm doing a LS3-6L80 swap into a 70 Chevelle. Both the engine and trans modules have circuit 5985(accessary wake up). It comes from the BCM and I don't quite understand if it is needed and what it does.
Old Dec 9, 2013 | 07:24 PM
71403's Avatar
"Accessory wake up" originates at the ign switch and passes thru the BCM then out to various modules. It is part of the power moding and RAP creature-features.
May set a power mode code (no SES light) but will run fine without it.
Old Dec 10, 2013 | 10:37 AM
mrttype's Avatar
Default Accessary Wake Up
Thanks alot. I'll make sure the code is turned off in the new software.
Old Mar 31, 2014 | 02:31 PM
mrttype's Avatar
Default LS3 Swap
My LS3 swap is finally done. Very little problems except for the power steering. I'm using the stock 2010 Camaro p/s pump. I have no power steering at an idle. At about 1200 RPMs, power steering is great. I changed the power gearbox on the Chevelle thinking that could be the problem (seeing it was the original) but it didn't help. Is the pump too week for a gearbox because it's made for a Rack? Any help would be appreciated.
