LS7 alternatives - Best value in large cube LS?
It looks like Texas Speed has some offerings but I'm leery of the reliability of a stroked 6.0 aluminum block. Can anyone recommend any other naturally aspirated LS crate engines that can produce 500HP / 500 ft lbs of torque below 5500 RPM? Suppliers?
Thank you
The 6.2 LS3 starts around 430hp. I don't think the LS3 was available at the time of their article but you can probably assume getting into the 500s is just as easy or easier.
A friend of mine took the bottom end of a truck 6.2 and built his own top end. With a turbo he is hoping for 800hp.
Beyond that, I don't know of a lot of people playing around with the 7.0s. The cost involved to mess with those engines is just beyond the reach of most of us.
Super Chevy article: http://www.superchevy.com/technical/...s/viewall.html
As for a create, I don't think you'll find a create to give you the power you're looking for short of the LS7.
The engine is designed for lots of low end torque and still used in boating applications. Probably better torque than a BOP 455. Raylar marine has lots of upgrades. I have not seen much in the automotive sector, but sure something is out there.
As for cost effective, guessing anything stock GM will be a fraction of hi performance LS454 or other strokers.
