TBI to LS1 fuel setup ??? Help!!!
Old Dec 11, 2013 | 08:07 PM
jamesyama27's Avatar
Default TBI to LS1 fuel setup ??? Help!!!
OK ...... I have 1990 chevy 1500 short bed. I am currently converting it to an LS set up. What can I do to get the fuel up to the motor???? What pump or set up would work best.
Thanks in advance
James
Old Dec 11, 2013 | 10:06 PM
i r teh noobz's Avatar
Is your pump internal? See if you can swap a Walboro 255 or similar pump into your current sending unit.
Another option would be to use a pump/sender or entire tank from a 99+ LS truck if it fits.
Old Dec 12, 2013 | 11:55 AM
91ls1silverado's Avatar
This is the fuel pump I'm using for my setup on my 91
http://www.highflowfuel.com/i-478352...1988-1995.html
Old Dec 12, 2013 | 01:26 PM
Thanks guys!!!
that helps allot
Im sure ill be back when I start trying to figure out the wiring part of this whole deal.
