GM Electronic Throttle Control
If the car fails the test it will go into limp or reduced power mode like you stated. That's normal with a malfunction. This also occurs when over zealous tuners start messing with the electronic throttle settings in the PCM file. Exceede the internal limits and the car goes into limp mode and all you get is 18 percent throttle.
E40 ecu will not work with the Lokar pedal unless wired correctly. Found this out with the turbo 69 Camaro we did. Swapped in a 08 truck pedal for testing since the connector is the same and reviewed the scanner data. Throttle opening voltages did not correspond with needed voltages so car would not accelerate.
I have tons more incompatibility examples and simply restating parts store interchangeability does not mean most parts function correctly.
I have over 2500 tune files in my repository, so I am not a rookie
I have several SAE documents on GM's TAC system. This is great information to have
I have GM engineering documents on the TAC system. This is even better information
The software I use on the 1 meg PCM has over 160 ETC parameters not including DTC's. Out of that 160 it has over 60 diagnostic parameters. This would include some of the voltage tables for the APP and TPS. This is how I learned how to do it
HPT will add parameters now without a huge delay
HPT has added parameters for the fuel gauge output from the PCM
HPT is adding all of the needed Knock Sensor Parameters to run the LS2 sensor on a older PCM.
I have NEVER bricked a 99 to 2010 LS/truck PCM
As of now, you have the ability to view and edit the actual hex code to see the differences and change them between various PCM files including the DBW limits and it's requirements to prevent limp mode or reduced power mode. So with the upcoming hp tuners capability, everyone will be able to edit the parameters so a physically smaller v6 style pedal can be used with any PCM.
Eric and myself gained a vast amount of knowledge interchanging parts years ago.
Again I will get with Bill and let him know what parameters need to be added.
I was just out running a test to set faults. The way I have it setup it will not go into REP with the engine running. KOEO it will.
When I set a fault I simply return the APP to 0 and it resets.
Currently I when the wrong way and about 1/4" = 80% and 1/2 " = 137% APP. When the TAC sees over 100% for a set duration it closes the throttle (in my test mode).
What would parts swapping do if you can not see the calibration in the PCM?
One question that has came up for years is if you get this part from that vehicle and that part from another vehicle and all of the part numbers match what the parts catalog shows why does it go into REP? Then you get an new part from the dealer and it works. It must be the magic smoke in the TAC module. I don't think so.
I guess the issue to has been with HPT.
HPT has hired 2 new engineers to work on software. This has allowed for them to free up someone to add parameters. EFILive has had the CAX to do you own, but with what HPT is doing they might come out the new leader in the tuning software market.
In my opinion and many others HPT has been like Apple. Great for beginners and great graphics. but limited in many areas. HPT has the software locked down in a manor that is not preferable to many tuners, I am not a segment swap fan at all. I think it is a huge mistake. HPT's software will not allow for the swaps by users. I feel that HPT will add parameters that will make segments swaps a thing of the past. I see them turning a corner
That's what I was thinking, but he said in an earlier post that the options are there and have been available for years.
Over the past year I have got really deep into Hex Editing. It takes time, but over time you start to see parameters in the bin file. I have revisited the TAC parameters over and over with just a little improvement. This 2005 OS just hit home with me and it clicked.
So you spent hours and hours going in circle and not making progress. If you would have dropped some cash in the right direction you could see what I see. We learn from our mistakes and I make a lot of them.
