DBW problems p1518
Old Dec 30, 2013 | 04:18 AM
JBT's Avatar
JBT
Default DBW problems p1518
I'm helping out a friend that's swapped in a 2002 5.3 with dbw in his old pickup.
When you turn on the ignition the pedal i dead and it throws the code p1518. If one clears the code (with HPT) the throttle works fine until one turns off the ignition.
What can the problem be?
Old Dec 30, 2013 | 10:35 PM
rascalking's Avatar
Just a thought...check your voltage when starting the engine. This code can come up with low voltage. This might explain why it works fine until you turn it off and restart. Depending on where you got the power for the ECM, it could be starving for voltage until the engine is running. Check your grounds to...
Old Jan 3, 2014 | 01:52 AM
69face's Avatar
if he soldered any of the connections, check for resistance in those wires after checking the above. any corrosion in wires that small can reek havoc on a dbw setup
Old Jan 3, 2014 | 12:49 PM
loweredd's Avatar
Check the wire for 12V WHILE cranking. You might have tapped into a circuit that is 12V in RUN only.
