throttle body conversion help
Old Jan 13, 2014 | 09:53 PM
Blackpony's Avatar
Default throttle body conversion help
I am currently running an 8 pin throttle body on my ls swapped truck, wanting to swap intakes over to where I can run the larger 87 mm 6 pin throttle body. Does anyone know if i wire the new pig tail up will the 6 pin throttle body work with my current pedal and tac module or am I going to have to swap some of those components out?
Old Jan 14, 2014 | 12:36 AM
Lsx Rubi's Avatar
Is it the ls2 style or ls3 throttle body ?
Old Jan 14, 2014 | 06:41 PM
Blackpony's Avatar
It will be a Ctsv throttle body which looks identical to a tbss. Blade opens the same direction, motor looks the same etc.
