po200 after ls1 swap
Old Jan 21, 2014 | 06:59 PM
cool breeze's Avatar
Default po200 after ls1 swap
So i finally got on it and went wot and short shifted around 5k rpm. Went to accell in 2nd gear and car went limp, little to no power. Felt like it was down 4 cylinders. Limped it off the highway to find i had a new error code.
Pulled the battery cable for 5 minute and restarted, everything is back to normal. What would cause it to throw a code.
Setup:
2002 ls1/t6 pullout with pcm
custom integrated harness into bmw e36 chassis
camshaft setup only, everything else is stock
Thanks!
